Let's talk about load times.
Forums: Let's talk about load times.
Postby adrencg » Mon Oct 17, 2011 8:26 pm
adrencg Mon Oct 17, 2011 8:26 pm
While I'm super impressed with how fast Octane is rendering frames -- the load times are KILLING the potential productivity. I realize this may be a technical problem that is standing in the way Face, but if I could suggest one thing that would immensely help rendering animation Octane, it would be getting data handshaking time down to something reasonable. Sometimes I spend 5 minutes(or more) exporting and loading a frame, but it renders in less than a minute.
Is this something on your list of improvement? I realize you've already made quite a bit of progress, because load times are better than they were before -- but still very slow if you're working with lots of geometry.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
adrencg
Re: Let's talk about load times.
Postby t_3 » Mon Oct 17, 2011 9:43 pm
t_3 Mon Oct 17, 2011 9:43 pm
adrencg wrote:While I'm super impressed with how fast Octane is rendering frames -- the load times are KILLING the potential productivity. I realize this may be a technical problem that is standing in the way Face, but if I could suggest one thing that would immensely help rendering animation Octane, it would be getting data handshaking time down to something reasonable. Sometimes I spend 5 minutes(or more) exporting and loading a frame, but it renders in less than a minute.
... quoting radiance a substantial better voxeling performance is already on the list of upcoming improvements for beta 2.6 - what will result in a notable better loading time for large poly scenes. and as soon octanerender "native" plugins become available, the whole exporting/importing process will be cutted to 0. so the only thing for you to hope is, that a xsi plug is in the works...
t_3
Postby face » Mon Oct 17, 2011 9:48 pm
face Mon Oct 17, 2011 9:48 pm
Here is a log i have made to show which times are used for specific data operations.
The testmesh was a textured sphere with 1mio tris.
// INFO : initializing: 0.0265087
// INFO : Vertex access: 0.0162558
// INFO : Vertex writing: 0.341689
// INFO : Normal access: 0.19016
// INFO : Normal writing: 1.39654
// INFO : Texture access: 0.0439852
// INFO : Texture writing: 0.936423
// INFO : Faces access: 1.00283
// INFO : Faces writing: 1.66027
// INFO : Cleanup: 0.00195059
// INFO : Overall: 5.62907
The faces used the most time because i need access to the indices which polygon use which vertex-,normal- and texture-index.
All in all you see, to write in the file is the bottleneck. Not the writing itself, but the time to convert the values to a writeable text format.
I have spend much time to find and integrate an alternative method which is faster than the standard method.
To seperate the process in multiple threads makes in my eyes not realy sense because on 4 cores i would maximum save the half time. To this time, the time to manage the treads will be added, so that you have maybe a plus of 1sec. per 1mio tris.
Another time killer is to uptade the progress bar. I think i have minimized the output of information so that, at this point, there is no more room for play with.
For around 2mio tris i need around 10sec to export. To import it in Octane, i need 40sec.
It´s also on the Octane side to optimize some things and this is not my bussiness...
face
http://vimeo.com/user2509578
face
Postby face » Mon Oct 17, 2011 9:52 pm
face Mon Oct 17, 2011 9:52 pm
t_3 wrote:... quoting radiance a substantial better voxeling performance is already on the list of upcoming improvements for beta 2.6 - what will result in a notable better loading time for large poly scenes. and as soon octanerender "native" plugins become available, the whole exporting/importing process will be cutted to 0. so the only thing for you to hope is, that a xsi plug is in the works...
Cutted to 0 isn´t correct, the access times will be needed, also the time to process the data and send they to the GPU.
face
face
Postby adrencg » Mon Oct 17, 2011 10:16 pm
adrencg Mon Oct 17, 2011 10:16 pm
All I know is...once this hurdle is out of the way, the sky is the limit for getting stuff done in Octane.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
adrencg
Postby t_3 » Mon Oct 17, 2011 10:22 pm
t_3 Mon Oct 17, 2011 10:22 pm
face
this is of course correct. but without the need to write and read to/from disk (and to do some transformations which are needed to do this), it'll still make a big difference...
t_3
Postby adrencg » Fri Jan 20, 2012 3:42 pm
adrencg Fri Jan 20, 2012 3:42 pm
I have to admit, the load times have been fantastic for the last couple of Octane releases. Seems 10 times faster.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
adrencg
Tue May 28, 2024 7:34 pm [ UTC ]
