OctaneRender® for Maya® 2.23.2 - 7.5 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
Quick-fix release.
  • Fixed the Linux bug (not able to find alembic export module).
Installation:
DOWNLOAD
OctaneRender for Maya - v7.5 Linux (19.1MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
matrix2012
Hi JimStar,
Thank you. :)
it works
many thanks for your hard work and support.
it would be great to ORBX import function. :D
Then you could from other 3D program the scene Apply and continue working with it
I will continue to test
Sorry for my bad english.
all the best
matrix2012
matrix2012
Hi JimStar,
When I create a OctaneLIGHT with Geometry type: Global IES light use it properly
But I use a Geometry Type: Movable proxy, Scatter and Reshapable proxy IES light they are not equal with Global. :?
See screenshot:
sorry for my bad English
Next version HERE.
Return to “Autodesk Maya”
