OctaneRender® for Maya® 2.21.1 - 6.4 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
THIS IS THE QUICK-FIX VERSION
  • Fixed value limits in Octane transform nodes.
CHANGES OF PREVIOUS VERSION
  • Added "out of core" settings to Octane globals.
  • Fixed the hair material UI bug.
  • Fixed the db dialog crash bug (happened if you pressed the "open" button the second time when the dialog was already opened).
  • Fixed the LiveDB crash when loading asset containing scattering medium.
  • Minor fixes...
DOWNLOAD
OctaneRender for Maya 2.21.1 - 6.4 (33.8MB autoinstaller file)
OctaneRender for Maya 2.21.1 - 6.4 Demo (30.9MB autoinstaller file)
Standalone: http://render.otoy.com/forum/viewtopic.php?f=33&t=44704
Yours,
The OctaneRender™ Team.
prodviz
Cheers Jim.
g0ll4m
what was the hair material bug?
Windows 10
Maya 2024.2
2 RTX 4090s 192 gb ram
g0ll4m
This was the UI bug, it did not affect the rendering. You were not able to connect the new hair material right from transform's attribute editor using button. Only using drag-n-drop or Hypershader.
prodviz
The Octane DB floating pallet gets sent to the back, when the main interface is selected.
Slimshader
Hello, I'm upgrading to 2.0 this week and I was wondering if anyone knows off hand which version is the stable one.
Thanks in advance!
Wenneker
I think the stable versions are found on the account pages.
https://render.otoy.com/account/download_archive.php
Most of the time the latest build is fine and I use that one.
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
abeoctane
Hi, I found a bug, the skip existing frames option when rendering is not working, octane render all the frames, not matter if the checkbox is on or off.
MTECH
I noticed that the material edge rounding feature does not work when a Mix material is assigned to geometry, even if both materials feeding the Mix material both have edge rounding values set.
The edge rounding is only visible if I assign one of the materials feeding the mix material directly to the geometry, but I need to use the Mix material to add a texture illumination map on a lot of building models but still keep glossy reflections for windows.
Will this be fixed or added in a future version of Octane for Maya? Thanks for all you've done so far!
Core i7 920 | 12 GB RAM | Nvidia GTX 470 & 260 | Win Vista x64 | Maya 2012.5 x64 | Octane beta2.57
nedan
abeoctane wrote:Hi, I found a bug, the skip existing frames option when rendering is not working, octane render all the frames, not matter if the checkbox is on or off.
This never worked, however it could be a very useful feature.
Return to “Autodesk Maya”
