OctaneRender® for Maya® 1.55 - 3.3 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed Sky colors bug.
  • Export to Octane now exports ORBX file.
  • Minor fixes...
DOWNLOAD
OctaneRender for Maya 1.55 - 3.3 (28.8MB autoinstaller file)
OctaneRender for Maya 1.55 - 3.3 Demo (26.6MB autoinstaller file)
Yours,
The OctaneRender™ Team.
prodviz
Hi Jim,
Should we use the export 'OctaneRender scene' to save out a ORBX file?
And with the alembic format, is it best to use:
Export All/OctaneRender alembic
or
Pipeline Cache/alembic cache/Export all to alembic?
cheers,
Steve
prodviz
When the Octane file comes in to Standalone, the PMC reverts to Direct lighting.
The PMC depth of 128 reverts to Direct Lighting's 5 spec and 2 Gloss.
When I change the render engine back to PMC, the limit for depth is 32.
Is there a way to override this?
cheers,
Steve
Next version HERE.
prodviz
Cool, cheers Jim.
Did you get a chance to look at this:
________________________________________________________________________________
cheers,
Steve
prodviz
I've tried to reproduce - works OK on my side...
prodviz
Hey Jim,
darn it, the PMC setting is working. Must be something I missed.
However, the depth of 128 in maya coverts to 32 for diff and 32 for spec.
cheers,
Steve
Return to “Autodesk Maya”
