OctaneRender® for Maya® 1.32 - 2.0 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • New 1.32 engine.
  • A lot of changes, bound to new engine. New nodes, changes of existing nodes, etc...
May not work properly with some scenes made in previous versions of plugin.
DOWNLOAD
OctaneRender for Maya 1.32 - 2.0 (27.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
solomon
Niiice!! I have been waiting for an update, thanks :)
Solomon W. Jagwe
solomon
k, some feedback, my scenes created in 1.20.2, 1.7 are not working correctly in the new build. They somehow look darker and the response to HDRi images is not quite as good as before... not sure what exactly caused that..
Solomon W. Jagwe
TBFX
Hi JimStar,
Seems that the octaneDiffuse material is no longer recognized as an octane material and is converted to gray when I start a render.
T.
TBFX
Also the colorCorrectTexture isn't passing the texture through. If you place it between a texture and the diffuse of a shader all you get is gray.
T.
Next version HERE.;)
Return to “Autodesk Maya”
