Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
- Fixed the UVs bug (jmfowler reported).
- Fixed the GPU checkboxes bug.
- Little bug fixes and improvements...
- Starting from this version the plugin uses the new "v1.0 RC3" engine. The versioning of the plugin is changed to more formal and universal: starting from this release the first part of the version string (before hyphen) will be the engine version, and the second part - is the version of plugin itself.
- The support of Maya 2013.5 added (thanks to phaskins).
- "Movable proxies" animation mode added. "Fast animation" checkbox in Octane settings is now "Animation mode" selector.
- New "White saturation" attribute in Octane Imager.
- New "Caustic blur" attribute in Octane "PMC" and "Path tracing" kernels.
- Daylight system attributes added to Octane SunSky node.
- Added "Max. textures count" to textures statistics.
- Added "Free memory" to memory statistics.
- In this version the new engine's API feature has used: the plugin can now detect some rendering failures.
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
