Alpha Channels For Materials - Possible ?
RobSteady
Is it possible to render out alpha channels for certain materials?
RobSteady
Nobody needs black/white masks? :?:
HHbomb
too bad that "Rendermask" script dont' work with octane... the maker of the script said that it will not work with octane...
gueoct
RobSteady wrote:Nobody needs black/white masks? :?:
i do, too !!!
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
RobSteady
Can anyone please tell me how to use Object-Id Render Element then?
It looks the same as Material ID.
RobSteady
I can use RenderMask from Scriptspot and switch to Scanline Render.
But it's not working when I want to render trees with opacity maps from Octane.
Btw. It's urgent ;)
RobSteady
I can do it manually by assigning a black diffuse material to everything except the trees.
Then give the trees an emmitting material with surface brigthness checked and illumination unchecked. I need to copy opacity maps from the leave materials.
Then render with Direct Light and no GI.
Takes forever...
RobSteady
Oookeeeey...
Back to V-Ray then.
Return to “Autodesk 3Ds Max”
