Hair and fur
MistAjuliax
Hi karba,
Do you think hair and fur will be increase with octane 3.x ?? Have any news from autodesk ? Do they provide you full access to the sdk to implement hair and fur better ?
Cheers.
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
DartFrog
I don't know if I understand your question.
Hair and Fur was supported in some version of octane's plugin. Then it wasn't supported in the version I'm using now, I have to convert all the hair to geometry. I'd imagine it will be enabled again at some point. If they release another "official" version of octane before 3.0, then I would guess it would be enabled but who knows.
MistAjuliax
DartFrog wrote:I don't know if I understand your question.
well, i mean a better support of hair and fur modifier than the actual. Random scale parameter doesn't work, tip/root material is not supported etc etc ... nothing work. Personnally i don't use hair and fur modifier to achieve hair, but i use a particle flow system, or a geometry instanced by hair and fur modifier.
It would be great to have an option to choose, between strands rendering, or geometry, and a full support of the hair and fur modifier, and a hair material ... karba has explained that autodesk don't provide him full access to the sdk of 3ds max that's why we do not have a better support.
So, i hope for the next major release a full support of hair and fur modifier which is included with 3ds max. I don't intend to purchase hairfarm or ornatrix because i'm a freelancer ...
suvakas
Standard Hair and fur has never been properly supported by Octane plugin. All solutions have been kind of "hacks".
Max SDK is too confusing to implement it. Otoy should contact Autodesk and try to solve it. I'm not sure why they haven't done it so far.
Suv
jagger
So how to render hair with octane in max? is hair farm supported? ornatrix?
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
Return to “Autodesk 3Ds Max”
