Frustrated Again
Forums: Frustrated Again
Re: Frustrated Again
Postby chae » Fri Sep 28, 2012 10:50 am
chae Fri Sep 28, 2012 10:50 am
So having used blender for a total of 4 days that means ??? :D :D :D :D :D :D
So use to using Max & CD4 adding a camera is a piece of p..s
chae
Postby matej » Fri Sep 28, 2012 10:57 am
matej Fri Sep 28, 2012 10:57 am
It means you go in the camera tab with your camera selected and delete what you have set in the circled field (or put an actual scene object there)
cgmo.net
matej
Postby chae » Fri Sep 28, 2012 11:14 am
chae Fri Sep 28, 2012 11:14 am
Matej you're my hero :lol: :lol: :lol:
I've searched high & low on Google on how to set up a simple Blender camera & does it tell you that anywhere !!!!!
Gees a totally different workflow & procedure & YES the model shows up in Octane (angelic music starts playing in the background)
Now to master materials - haaaa haaaaa
Can go to bed & rest easy tonight - the license maybe purchased soon
chae
Postby matej » Fri Sep 28, 2012 11:17 am
matej Fri Sep 28, 2012 11:17 am
The error message is a bit confusing, but it shows that Lionel (the author of the Blender to Octane exporter) has a sense of humor :D
cgmo.net
matej
Postby kavorka » Fri Sep 28, 2012 12:23 pm
kavorka Fri Sep 28, 2012 12:23 pm
When you export to Octane, it doesn't care how many layers or objects you have, it merges everything. It only looks at the materials applied. So you need to apply a new material to each object that you want to be able to modify in Octane (each material will show up as an output in your object node). With the stand alone (and integrated max plugin) you can load multiple objects and instances and Octane will recognize them.
Also, select your object and click "N", this will bring up the properties panel on the right side of the view port, near the top it will tell you the size of your object, seems like you fixed the problem, but your object may have gotten scaled up/down somewhere in the export process.
kavorka
Postby chae » Sat Sep 29, 2012 12:12 pm
chae Sat Sep 29, 2012 12:12 pm
Thank you...the light bulb finally came on :lol: :lol:
Apply a default material in Blender then export to Octane VOILA all my layers/items appear in Octane....so use to simply pulling in a model/creating a model in MAX or CD4 without materials then into Maxwell Render.
Now to replicate my Maxwell Render materials into Octane
License may get purchased tomorrow :D
chae
Previous
Return to Demo Version Questions & Discussion
Who is online
Users browsing this forum: No registered users and 14 guests
Thu Jun 06, 2024 6:56 pm [ UTC ]
