Missing Orbx exporter under Octane Render Settings
Forums: Missing Orbx exporter under Octane Render Settings
Discussion Forum for the Render Network
For support questions please visit help.otoy.com or contact [email protected]
Postby octane_berlin » Mon Jun 19, 2023 9:44 am
octane_berlin Mon Jun 19, 2023 9:44 am
(I am using Cinema 4D R25.117 and the latest version of Octane.)
As far as I understand, the suggested way of using RNDR is via the Render Settings:
https://know.rendernetwork.com/getting- ... x-exporter
David shows in the tutorial that there is an ORBX Exporter supposed to be, as you can see in my screenshot, this function does not exist in my settings.
What am I doing wrong, please?
octane_berlin
Re: Missing Orbx exporter under Octane Render Settings
Postby bepeg4d » Tue Jun 20, 2023 8:52 am
bepeg4d Tue Jun 20, 2023 8:52 am
probably you have installed an outdated version of c4doctane plugin, please remove the installed c4doctane version and upgrade to 2022.1.1-R5:
https://render.otoy.com/customerdownloa ... ed_win.rar
In this version, there is also a new optimized .orbx export in Live View menu File/Export to../Animated package for RNDR (.orbx):
ciao,
Beppe
Postby octane_berlin » Tue Jun 20, 2023 3:12 pm
octane_berlin Tue Jun 20, 2023 3:12 pm
Thank you, now everything is in order. It's weird, because I triple checked that and always got the answer: 'You are using the latest version of the plugin. There are not any newer versions to download!'.
Doesn't seem reliable. Anyways, is there a difference between the export you mentioned and doing it via the Render Settings? The file size appears to be the same ...
octane_berlin
Postby bepeg4d » Wed Jun 21, 2023 6:57 am
bepeg4d Wed Jun 21, 2023 6:57 am
Ok, great!
Unfortunately, the "check for updates" command doesn't work, always better to check at OTOY-Maxon release forum page, the latest version is always on top:
viewforum.php?f=85
About new exporter command, it should be faster is some circumstances.
Happy GPU rendering!
ciao,
Beppe
Return to The Render Network
Mon May 20, 2024 3:26 pm [ UTC ]
