OctaneRender for Maya 2023.1.2-22.12 [OBSOLETE]
Forums: OctaneRender for Maya 2023.1.2-22.12 [OBSOLETE]
Moderator: JimStar
Postby JimStar » Sun Feb 11, 2024 6:21 pm
JimStar Sun Feb 11, 2024 6:21 pm
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2019, 2020, 2022, 2023 and 2024 64-bit on Windows, MacOS and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
Changes since version 22.11:
  • Fixed a bug: max-samples override command line key did not work in batch mode.
NOTE: There is a regression/bug in the 2023.1.2 engine's scene-export functionality. Thus the animated scene export with embedded alembic may not always work in this release. Should be fixed later. Stick to 22.10 as a workaround if animated export with embedded alembic is needed.
NOTE: The macOS libs in Octane 2023.1.2 SDK are not signed, thus this plugin version is not Apple-notarized.
NOTE: Directional light in current 2023.1 Standalone is not affected by its parent transform rotation at all. This is why you can only rotate this light in Maya by a transform node connected to this light-node's "Transform" plug. At least for current Octane engine version...
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
JimStar
Re: OctaneRender for Maya 2023.1.2-22.12 [STABLE]
Postby hgarrou » Fri Apr 12, 2024 7:32 pm
hgarrou Fri Apr 12, 2024 7:32 pm
I'm really interested in testing to see if 2023 1.3 has fixed animated scene export with embedded alembic. Any timeframe for when you'll release the Maya plugin for 1.3?
hgarrou
Postby BK » Tue Apr 16, 2024 2:59 am
BK Tue Apr 16, 2024 2:59 am
hgarrou wrote:I'm really interested in testing to see if 2023 1.3 has fixed animated scene export with embedded alembic. Any timeframe for when you'll release the Maya plugin for 1.3?
Hi Hgarrou,
Thanks for the post.
We are working on it and will post it asap!
cheesrs
Kind Regards
bk3d
BK
Return to Releases
Sun Apr 28, 2024 3:14 pm [ UTC ]
